HELLOY REBJATA!!
Sevodnja sdelal diagnostiku svojevo xc90 2003. benzin/gaz, dvigatelj 2.9 goda s programmoj Autocom CARS CDP+ | 2013 Release 3 (2.13.3)
Vikinul celuju kuchu oshibok, hotel sprositj vashego soveta.
Sprashival u neskolkih mehannikov, vse vinjat v oshibkah gazovuju ustanovku, nascjot elektroniki vse molchat.
V spiske jestj parking sensor kotorij nedavno odklucilsja no vsjo ostalnoje rabotajet, obogrev zadnego stekla, elektronika posazhirskoj dveri i drugije vessi.
Mozet jestj ktoto kto mozhet objasnitj ili skazatj kuda obratitsja stobi nenadobilo vikinutj 100 evro za diagnostiku stobi ponatj sto s mashinoj polnaja popa i vobse ludse "pokrasitj i vikinutj"
Fault codes
Petrol (B6294T - Motronic ME7 - MT/AT)
DTC Description
2810 - Upstream lambda sensor heating cirucit; current implausible
- Intermittent
271A - Adaptiv lambda adjustment bank 2, incorrect
- Intermittent
290A - Upstream lambda sensor 2; invalid signal
- Intermittent
6806 - Turbo charge regulator valve
- Intermittent
Brake (ABS (BCM) - Mark 25)
DTC Description
0100 - Communication, CAN bus
- Permanent
Instrument (Instrument - DIM (DIM (Driver Info. Module)))
DTC Description
E003 - Module Configuration Failure
- Intermittent
Climate (Climate control - CCM (Climate control ))
DTC Description
0021 - Air quality sensor, internal fault
- Permanent
0004 - Compressor, faulty signal
- Permanent
Gearbox (All Wheel Drive - Haldex)
DTC Description
0003 - Control unit power supply
- Permanent
Immobiliser (Immobiliser - Diagnose (CEM))
DTC Description
5B01 - Left heater pad, incorrect signal
- Intermittent
1A62 - Communication with ECM, Engine Control Module
- Intermittent
Multifunction (Central electronics - CEM (Central electronics))
DTC Description
- Permanent
- Permanent
Multifunction (Driver door - DDM (Driver Door Module))
DTC Description
- Intermittent
Multifunction (Infotainment - ICM (Infotainment module (ICM)))
DTC Description
1A52 - Communication with antenna module (ATM), signal missing
- Intermittent
Multifunction (Passenger door - PDM (Passenger Door Module))
DTC Description
002B - Mirror motor MC, too low signal
- Intermittent
- Intermittent
Multifunction (Rear electronics - REM (REM (Rear Electronic Module)) - Xenon
calibration)
DTC Description
8F63 - Relay, rear windshield defroster. Signal not present
- Intermittent
1A05 - Relay, 15i power supply. Too low signal
- Intermittent
4F45 - Parking assistance sensor 4
- Permanent
Multifunction (Steering wheel electronics - SWM (SWM (Steering Wheel
Module)))
DTC Description
- Intermittent
Service Light Reset (SLR) (Reset service - Diagnostic reset (Recall service
message) - DIM (Driver Info. Module))
DTC Description
- Intermittent
Vtoroj test:
ECU 11 Engine controllers
Standard EOBD
MIL on
DTC 3
Readiness tests
Misfire Yes
Fuel system Yes
Comprehensive component Yes
Catalyst No
Evaporative system Yes
Oxygen sensor No
Oxygen sensor heater Yes
Address: Jaunceltnes 4, Aizkraukle
Postal address: LV5101, LATVIJA
Confirmed and stored codes (Mode 03)
ECU DTC Description
11 P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
11 P2179 System Too Lean Off Idle (Bank 2)
11 P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
Pending codes in previous and current driving cycle (Mode 07)
ECU DTC Description
