Volvo xc90 2003 celaja kucha oshibok
Сообщение calabria » 06.10.2014, 19:28
HELLOY REBJATA!!
Sevodnja sdelal diagnostiku svojevo xc90 2003. benzin/gaz, dvigatelj 2.9 goda s programmoj Autocom CARS CDP+ | 2013 Release 3 (2.13.3)
Vikinul celuju kuchu oshibok, hotel sprositj vashego soveta.
Sprashival u neskolkih mehannikov, vse vinjat v oshibkah gazovuju ustanovku, nascjot elektroniki vse molchat.
V spiske jestj parking sensor kotorij nedavno odklucilsja no vsjo ostalnoje rabotajet, obogrev zadnego stekla, elektronika posazhirskoj dveri i drugije vessi.
Mozet jestj ktoto kto mozhet objasnitj ili skazatj kuda obratitsja stobi nenadobilo vikinutj 100 evro za diagnostiku stobi ponatj sto s mashinoj polnaja popa i vobse ludse "pokrasitj i vikinutj"
Fault codes
Petrol (B6294T - Motronic ME7 - MT/AT)
DTC Description
2810 - Upstream lambda sensor heating cirucit; current implausible
- Intermittent
271A - Adaptiv lambda adjustment bank 2, incorrect
- Intermittent
290A - Upstream lambda sensor 2; invalid signal
- Intermittent
6806 - Turbo charge regulator valve
- Intermittent
Brake (ABS (BCM) - Mark 25)
DTC Description
0100 - Communication, CAN bus
- Permanent
Instrument (Instrument - DIM (DIM (Driver Info. Module)))
DTC Description
E003 - Module Configuration Failure
- Intermittent
Climate (Climate control - CCM (Climate control ))
DTC Description
0021 - Air quality sensor, internal fault
- Permanent
0004 - Compressor, faulty signal
- Permanent
Gearbox (All Wheel Drive - Haldex)
DTC Description
0003 - Control unit power supply
- Permanent
Immobiliser (Immobiliser - Diagnose (CEM))
DTC Description
5B01 - Left heater pad, incorrect signal
- Intermittent
1A62 - Communication with ECM, Engine Control Module
- Intermittent
Multifunction (Central electronics - CEM (Central electronics))
DTC Description
- Permanent
- Permanent
Multifunction (Driver door - DDM (Driver Door Module))
DTC Description
- Intermittent
Multifunction (Infotainment - ICM (Infotainment module (ICM)))
DTC Description
1A52 - Communication with antenna module (ATM), signal missing
- Intermittent
Multifunction (Passenger door - PDM (Passenger Door Module))
DTC Description
002B - Mirror motor MC, too low signal
- Intermittent
- Intermittent
Multifunction (Rear electronics - REM (REM (Rear Electronic Module)) - Xenon
calibration)
DTC Description
8F63 - Relay, rear windshield defroster. Signal not present
- Intermittent
1A05 - Relay, 15i power supply. Too low signal
- Intermittent
4F45 - Parking assistance sensor 4
- Permanent
Multifunction (Steering wheel electronics - SWM (SWM (Steering Wheel
Module)))
DTC Description
- Intermittent
Service Light Reset (SLR) (Reset service - Diagnostic reset (Recall service
message) - DIM (Driver Info. Module))
DTC Description
- Intermittent
Vtoroj test:
ECU 11 Engine controllers
Standard EOBD
MIL on
DTC 3
Readiness tests
Misfire Yes
Fuel system Yes
Comprehensive component Yes
Catalyst No
Evaporative system Yes
Oxygen sensor No
Oxygen sensor heater Yes
Address: Jaunceltnes 4, Aizkraukle
Postal address: LV5101, LATVIJA
Confirmed and stored codes (Mode 03)
ECU DTC Description
11 P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
11 P2179 System Too Lean Off Idle (Bank 2)
11 P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
Pending codes in previous and current driving cycle (Mode 07)
ECU DTC Description
calabria
Машина: volvo xc90
Двигатель: t6
Трансмиссия: automatic
Re: Volvo xc90 2003 celaja kucha oshibok
Сообщение solova64 » 06.10.2014, 21:25
Я затрудняюсь вам ответить, потому что ошибки не от VIDA. И когда долго не подключаеш диагностику остается очень много мусора в компе.
Ошибки после диагностики они вам стёрли?
Лучше сделайте диагностику с VIDA, тогда гораздо быстрей дадут ответ.
Потому что очень много появляются людей с оборудованием DICE и с программным обеспечением VIDA.
DIM - это приборная панель. У вас какие то проблемы с приборной панелью есть? Лампочка индикатора не горит, стрелки не так показывают, часы бегут, SRS-AIRBAG SERVICE URGENT на бортовом компе пишет, питания пропадает или какая то другая причина есть?
Если есть возможность, пишите кириллицей, а то немного тяжело читать.
Сообщение calabria » 06.10.2014, 22:34
Диагностику делал сам, после стёр все ошыбки. Первый тест, который проверяет електронику, викинул всё тоже самое. Ошыбки с двигательем пропали.
на бортовом компе показивает толко неопходимость обратится в сервис, но ето изза проблемного паркинг сэнсора.
приборную панель проверял отдельно, всё ок.
Именно это и удивило что по електронике никаких проблем нечувствую, кроме одного случая когда одно зеркало заднего вида открылось а второе нет.
calabria
Машина: volvo xc90
Двигатель: t6
Сообщение solova64 » 06.10.2014, 23:04
Запускали диагностику для панели?
Когда мигала панель символ двигатель гарел или нет?
phpBB [video]
Сообщение calabria » 07.10.2014, 15:52
нет, символ негорел.
calabria
Машина: volvo xc90
Двигатель: t6
Сообщение solova64 » 07.10.2014, 21:18
Если двигатель работал во время проверки, тогда в порядке.
Сообщение calabria » 07.10.2014, 22:00
Я завтра попробую ешё раз и отпишусь.
calabria
Машина: volvo xc90
Двигатель: t6
Сообщение ROMA » 31.07.2015, 00:35
Что бы не создавать новую тему решил написать в эту.
Комп всё время выдавал 2 сообщения- anti-slid нужен сервис и проблема с подушками безопасности. С товарищем подключили сканер сегодня и стёрли ошибки, при заводке они опять появились, при далнейшей проверке выяснилось что генератор даёт всего 12 вольт, а при вкл. фарах и обогреве зеркал вообще 11 вольт.
При запуске двигателя резко падает до 7 вольт и сразу выскакивают эти ошибки. Получается что причина в падении напряжения или в другом чём то? никаких проблем в этих блоках программа не показала.
За одно вопрос, что может быть с генератором, щётки..? :russ:
При подключении сканера вышла интересная вещь - программа писала что машина не отвечает, потом вставили 2005г. хотя по паспорту 2004 декабрь вроде, и сразу всё подключилось.Сканер не вольвовский а какой то универсальный для всех машин.
ROMA
Машина: VOLVO XC 90
Двигатель: 2.4 D
Сообщение mitja » 31.07.2015, 07:39
Модельный год у Вольво меняется в августе , потому у Вас машина 2005 года. Чем Вы диагностировали? Vida сама определяет год машины по VIN.
Сообщение ROMA » 31.07.2015, 10:57
Сканер не VIDA а какой то универсальный для всех машин. Не знаю названия, если интересно могу спросить.
Ну а проблема в генераторе или в чём то другом..?
ROMA
Машина: VOLVO XC 90
Двигатель: 2.4 D
