ICM-DC02 Связь модуля управления. Сигнал отсутствует
Re: ICM-DC02 Связь модуля управления. Сигнал отсутствует
Сообщение oceanr » 03.11.2022, 18:55
Информация из VIDA:
Read the section PRODUCT SPECIFICATIONS > DESIGN AND FUNCTION > 3 Electrical system > 37 Cables and fuses > MOST network
The control modules on the MOST network should be positioned in a particular order. If this order is not followed, the fault-tracing of the MOST network will deteriorate.
When further control modules are added to the MOST network, these should be placed in the correct order on the network to make it easier to fault-trace the control modules. If the control modules are connected in another order, this does not effect the function of the MOST network, but fault-tracing will be compromised. The control modules should be placed in the following order:
Infotainment Control Module (ICM) (16/94)
Multimedia module (MMM) (16/108)
CD module (MP2) (16/106)
Phone module (PHM) (16/60)
MD module (MP1) (16/107)
Audio module (AUD) (16/105)
Subwoofer module (SUB) (16/79)
Antenna module (ATM) (16/110).
If the MD module (MP1) is installed as an aftermarket accessory in a car with a phone module (PHM) and CD module (MP2), the MD module (MP1) will change positions with the phone module (PHM).
If the configuration of the MOST network in the car is minimal, the following control modules are connected:
Infotainment control module (ICM)
the audio module (AUD)
the antenna module (ATM).
Ring break diagnostics
General
This function is important when fault-tracing the MOST network. Ring break diagnostics are used when there is an open-circuit in the MOST network and diagnostic trouble code (DTC) ICM-DC02 has been stored in the infotainment control module (ICM).
During fault-tracing, all control modules transmit a message to the infotainment control module (ICM) in reverse order in relation to the position on the network. This means that the aerial module (ATM) is first, not last. The control module which is not working will not transmit an answer to the infotainment control module (ICM). This also means that the control modules connected after the defective control module will be unable to transmit a message to the infotainment control module (ICM).
The same applies in the event of an open-circuit in the fibre optic cable in the MOST network. None of the control modules before the open-circuit will be able to send their message to the infotainment control module (ICM). The infotainment control module (ICM) is then able to calculate the position of the open-circuit from the incoming messages.
Hint:
It is important to know which control modules are connected and in what order to identify the control module which sends each message.
oceanr
Сообщение bailini » 16.02.2023, 14:55
Добрый день. Новичёк тут, поэтому простите за тупость.
Наткнулся в просторах интернета на эту тему.
Проблема следующая:
Включается радио, проходит секунд 10-20 и выключается. Потом через 2-3 секунды включается и опять работает секунд 20. Что-то типо перезагрузки. Иногда даже 5 секунд не работает. Если зупустить навигацию (экран), то также перезагружается, когда пропадает звук и опять включается.
Столкнулся с этим впервые и уже 2 дня меня преследует эта проблема. Куда обращаться в Риге к сожалению не знаю. В электронике тоже полный ноль.
Может кто подскажет что это такое и как лечится?
Машина Volvo S80 2007 года VIN YV1AS694071033820
bailini
Трансмиссия: AT
Клубная атрибутика: bailini
Сообщение gljuk » 16.02.2023, 15:09
Не 100%, но близко к этому, что модуль ICM помирает. Лечится ремонтом, просто так заменить без прописки не получится
Русификация, конфигурация.
gljuk
Двигатель: 2.5D
Трансмиссия: AUT
Сообщение bailini » 16.02.2023, 15:17
Не подскажете куда обращаться и сколько это приблизительно может стоить?
bailini
Трансмиссия: AT
Сообщение Normund » 17.02.2023, 14:06
bailini
Стучи телеграмму stark-у. Или звони на Sila-2. https://volvo-club.lv/avtoservis
Normund
Трансмиссия: Aisin
Сообщение bailini » 18.02.2023, 09:03
gljuk писал(а):Не 100%, но близко к этому, что модуль ICM помирает. Лечится ремонтом, просто так заменить без прописки не получится
Начитавшись форумов, заметил одну особенность. У всех тухнет ICM, а мой продолжает подсвечиваться и показывать температуру климы. Пропадает лишь звук и отображение радиостанции. На CD или Aux тоже самое. При перезагрузке звука издаётся щелчок то в пределах ICM, то слышно в колонках.
Куда копать то?
bailini
Трансмиссия: AT
Сообщение gljuk » 25.02.2023, 19:26
В сторону любого из модулей на шине MOST. Уилок залило водой, блок MMM итд
gljuk
Двигатель: 2.5D
Трансмиссия: AUT
Сообщение bailini » 28.02.2023, 08:48
gljuk писал(а):В сторону любого из модулей на шине MOST. Уилок залило водой, блок MMM итд
Усилка под сидением у меня нет. Бомж комплектация. Из наворотов тольто синий зуб для звонков и аукс.
Может есть у кого схема где эти все блоки стоят на S80 2 поколения?
Синий зуб вроде в бардачке, а навигация в багажнике. Остальное не знаю где.
bailini
Трансмиссия: AT
