Расшифровка блоков управления Volvo
СообщениеДобавлено: 20.03.2009, 00:19
Glossary
Control units
ABS Anti Block System
ADM Additive Dosing Module
AEM Accessory Electronic Module
AFM AM FM Module
ATM Antenna Module
AUD Audio Module
AUM Audio Module
BCM Break Control Module
CCM Climate Control Module
CEM Central Electronic Module
CPM Combustion Preheater Module
DDM Driver Door Module
DEM Differential Electronic Module
DIM Driver Information Module
ECM Engine Control Module
EPS Electrical Power Steering Module
GPS Global Positioning System Module
ICM Infotainment Control Module
KVM Keyless Vehicle Module
MMM Multi Media Module
MPM Mediaplayer
MP1 Media Player 1 [Minidisc]
MP2 Media Player 2 (CD)
PAM Parking Assistance Module
PDM Passenger Door Module
PHM Phone Module
PSM Power Seat Module
REM Rear Electronic Module
RTI Road Traffic Information
SAS Steering Angle Sensor
SRS Supplementary Restraint System
SUB Subwoofer
SUM Suspension Module
SWM Steering Wheel Module
TCM Transmission Control Module
TMC Traffic Channel Module
TRM Trailer Module
UEM Upper Electronic Module
Shortenings
A/C Air Conditioning
ACM Alternator Control Module
AP Accelerator Pedal
AQS Air Quality Sensor
BSC Body Cluster Stability Sensor
CAC Charge Air Cooler
CMP Camshaft Position Sensor
CP Canister Purge
DSTC Dynamic Stability Traction Control
DTC Diagnostic Trouble Code
ECT Engine Coolant Temperature
EGR Exhaust Gas Recirculation
ETM Electronic Throttle Module
EVAP Evaporative Emission System
FC Engine Cooling Fan
FP Fuel Pump
GDL Gas Discharge Lamp Module
GSM Gear Selector Module
HO2S Heated Oxygen Sensor
IAT Intake Air Temperature
KD Kick Down
KS Knock Sensor
LCM Left Camera Module
LSM Light Switch Module
MAF Mass Air Flow
MAP Manifold Absolute Pressure
MIL Malfunction Indicator Lamp
OWS Occupant Weight Sensor
RCM Right Camera Module
RPM Engine Speed
RSM Rain Sensor Module
SCL Steering Column Lock Module
SCM Siren Control Module
SCU Start Control Module
SRI Service Reminder Indicator
SRL Service Reminder Lamp
SIPS Side Impact Protection System
TC Turbo Charger
TWC Three-way Catalytic Converter
VNT Variable Nozzle Turbo
VSS Vehicle Speed Sensor
WMM Wiper Motor Module
ESP - Electronic Stability Program
