The FOB (Forward Operating Base) serves as the central hub for the DMZ mode in Call of Duty: Modern Warfare 4. Following a successful exfiltration from the Hajin Exclusion Zone, players return here to organize their loot, plan their next infiltration, and make progress on long-term objectives. Mastering this system is key to consistently successful exfiltrations and minimizing the risk of failure during your deployments.
Core FOB Facilities
Upon unlocking the DMZ mode in Call of Duty: Modern Warfare 4, players gain immediate access to several foundational facilities - no level requirements necessary. The Operators panel is used to manage your playable operators, check their MIA (Missing in Action) status, and allocate Trait points. The "Stash/Loadout" area functions as your storage and equipment station; any weapons, armor, keys, or materials successfully extracted from the field are deposited into the Stash - a shared inventory accessible by all your operators - where you can configure your loadouts before heading into a match.
DMZ Orders display your primary missions, dynamic objectives, and their associated rewards, allowing you to set your mission focus before each deployment. The Firing Range lets you test weapon attachments and optics, saving you the trouble of repeatedly entering live matches just to fine-tune your setup. Survival Kits provide pre-packaged supply bundles, perfect for quickly restocking armor and medical items. To ease the difficulty of the early-game experience, some players opt to buy CoD MW4 bot lobbies, allowing them to familiarize themselves with the controls and weaponry in a lower-pressure environment.
Advanced Facilities Unlocked via DMZ Progression
As you level up in Call of Duty: Modern Warfare 4 DMZ, the FOB will gradually unlock more high-value features. Reaching Level 2 grants access to the "3D Printer," which allows you to craft high-tier gear - such as advanced armor, backpacks, killstreaks, and night-vision goggles - by using raw materials scavenged from the map. This facility is also essential for upgrading other modules within the FOB as you progress further.
As your level continues to rise, the Boss Board, Vendor, and Gunsmith become available. The Boss Board allows you to spend DMZ Cash to buy intelligence on the locations of lieutenants and commanders, facilitating targeted hunts for high-reward bosses. The Vendor offers a daily rotating inventory of weapons and equipment, while the Gunsmith enables custom weapon modifications, including the addition of Apex Attachments. To quickly gather the materials needed for upgrades, collecting specific CoD MW4 DMZ items can significantly shorten your progression time, saving you from repetitive, tedious grinding.
Core Rules for Stash and Inventory Management
Your FOB Stash has an initial capacity limit that expands as your DMZ level increases; items stored here are kept permanently. It is crucial to distinguish between your FOB Stash and your in-game Backpack. Items in your backpack - unless placed in a Secure Slot - will be lost if an extraction fails. To keep items permanently, you must successfully extract with them and then manually move them into your FOB Stash.
A common mistake for beginners is entering a match with valuable items still in their backpack; if you die, everything is lost. It is best to establish a routine: immediately organize your inventory after a successful extraction, moving rare keys and high-value materials into your FOB Stash, while keeping only the supplies needed for your next run in your active loadout. Having a well-stocked stash provides a much larger margin for error, whether you are completing missions, challenging bosses, or engaging other players.
Long-term FOB Planning and Gameplay Strategy
Developing your FOB is a long-term process - there is no need to rush to max out every facility at once. In the early stages, prioritize expanding your Stash capacity and upgrading the 3D Printer to ensure you have space for supplies and can craft your own gear. In the mid-game, unlock the Boss Board to consistently farm loot, and in the late game, unlock the Gunsmith to build your ultimate, customized weapon loadouts.
If you are more focused on PvP extraction and want to practice your combat rhythm, you can use CoD: Modern Warfare 4 bot lobbies to familiarize yourself with map locations and hone your skills in a low-pressure environment. While your FOB doesn't directly boost your combat damage, a robust supply reserve and reliable gear-crafting capabilities will ultimately determine how far you can progress within the Hajin Exclusion Zone.
